Naiad theme for H16 (Circular nodes - one shape to rule them all)
   23546   35   5
mtucker
Yeah, that's the “current” node, which may or may not also be “selected”. Maybe just making the color more different from the “selected” color would be enough. In the old network editor I think “current” was white?
Hi Marc,
I hope I'm not bumping the thread needlessly, as I consider this to be bordering on the trivial. I don't remember the color prior to 16, but perhaps choosing a color that's further away on the spectrum from yellow/pink would be a better choice. An olive green maybe? Again, feel free to ignore this suggestion, as I said earlier, there are bigger fish to fry.
McNistor
Long, long ago, prior to Houdini 9, a non-selected current node actually was outlined in green.
jason_iversen
This appeared elsewhere - I cannot take credit for it, except for lifting it shamelessly without the author's permission.
oh dear, I thought what happens in alpha, stays in alpha. ;-)
Is the HOUDINI_NODE_WIDTH env no longer supported with H16? It doesn't seem to do anything as far as I've tried.
No, HOUDINI_NODE_WIDTH has no meaning now that you can define node shapes of any size and shape.
Will there be an Orbolt™ Asset Store for node shapes?
jsmack
That would sort of imply official support for custom node shapes, so for now, no.
jason_iversen
import json
def drawOutline( outline, vex_func_name ):
    vexcode = "void {}() {}\n".format(vex_func_name,'{')
    vexcode += '  int pr,pt;\n'
    vexcode += '  pr = addprim(0,"poly");\n'
    for p in outline:
        vt = " set( {}, {}, 0 )".format(*p)
        vexcode += "  pt = addpoint(0,{});\n".format(vt)
        vexcode += "  addvertex(0,pr,pt);\n"
    vexcode += "}\n"
    vexcode += "{}();\n\n".format(vex_func_name)
    return vexcode
import math
def drawLine( line, vex_func_name ):
    vexcode = "addattrib(0,\"point\",\"tangent\",{0,0,0});\n"
    vexcode += "void {}() {}\n".format(vex_func_name,'{')
    vexcode += '  pr = addprim(0,"polyline");\n'
    for p in line:
        x,y,theta = p
        theta = hou.hmath.degToRad(theta)
        vt = " set( {}, {}, 0 )".format(x,y)
        vexcode += "  setattrib(0,\"point\",\"tangent\",pt,-1, set( {},{},0 ) );\n".format(math.cos(theta),math.sin(theta))
    vexcode += "}\n"
    return vexcode
shapecode = hou.pwd().inputs()[0].parm('shape_json').eval()
shape = json.loads( shapecode )
outline = shape['outline']
code = drawOutline( outline, "outline" )
flags = shape['flags']
flagcode = ''
for flag in flags.keys():
    flagoutline = flags[flag]['outline']
    funcname = 'flag_{}'.format(flag)
    flagcode += drawOutline( flagoutline, funcname )
code += flagcode
code += drawLine(shape['inputs'],'inputs')
code += drawLine(shape['outputs'],'outputs')
return code
Amazing code man, thx
Has anyone been able to get custom shapes working?
I've been unable to get the HOUDINI_PATH setup properly. trying something like
HOUDINI_PATH = ${HOME}/houdini16.0/config/NodeShapes;&
It seems like the shapes in $HFS are still taking precedence over the ones in my home dir.
(This is on Linux)
Houdini is going to look in any config/NodeShapes folders that exists in the HOUDINI_PATH so you shouldn't be pointing your HOUDINI_PATH explicitly to a directory containing those shapes.
Also, if that's where your shapes are then you shouldn't need to set the HOUDINI_PATH at all to have them found since $HOME/houdiniX.Y is going to be in your HOUDINI_PATH already.
Edit:
I've found that attempting to explicitly override the default shape definitions does not work well/at all because it seems that Houdini handles shapes in a last is best manner so if you have your shape named “foo” before a shape named “foo” in $HFS then it will see yours, but then see the HFS one and use that instead
Edited by graham - May 3, 2017 14:28:52
Thanks for clearing that up for me Graham.
Should custom shapes show up in the list returned by doing:
hou.ui.paneTabOfType(hou.paneTabType.NetworkEditor).nodeShapes()
I have test.json (with “name”: “test” specified) file in the config/NodeShapes/ in my home houdini dir.
'test' doesn't show up in the node shapes list, and trying to set the userData ‘nodeshape’ to ‘test’ seems to just give me the standar ‘rect’ shape.
Since we were also looking for a way to create custom node shapes for our own workflow, we came up with a tool (thanks to the valuable input from this thread) that lets you convert your curves into the required JSON format. The scenefile (along with an explanation of how to use it) can be found here: https://vimeo.com/221182957 [vimeo.com]
If you just quickly want to create the JSON file, download the scenefile and watch the first minute. The rest explains how we set up the file itself.
We hope you find it useful!
To make things even easier, we created an HDA out of the whole setup that even writes the JSON file for you. The setup is pretty straightforward: plugin the curves as shown below (merge the flags using the “Custom Node Shape: Flags” SOP) and hit “Save”.
Download the file here if you like (there's also a walkthrough on how to wire everything in): https://vimeo.com/223222233 [vimeo.com]
Cheers!
Edited by bjs - June 30, 2017 12:00:51
Nice one man. I bet SESI might consider using this instead of their internal tool whatever it might be
The tool by bjs is still the best way to do this, amazing work!
Has anyone figured out how to embed custom node shapes in an HDA?
I added the json in the extra files section and am trying the following code in the OnCreated script:
node = kwargs['node']
node.setUserData("nodeshape", "opdef:/DS::Sop/my_node::2.0?myShape")
But it seems to be the wrong syntax. It seems to work for something like:
node.setUserData(“nodeshape”, “bulge_down”)
Edited by DASD - Sept. 18, 2020 06:45:00
Does anyone have the hip file/HDA referenced two posts earlier?
The download link is gone.
