I'm getting this warning when loading at H20 scene into H20.5
HDK Warning: GUI_PrimClusterMeshHook and GUI_PrimClusterMeshHook have the same priority (0)
HDK Warning: GUI_PrimClusterMeshHook and GUI_PrimClusterMeshHook have the same priority (1)
Can not find any info on this. I am having problems rendering (with Redshift) though. Is it related - no idea.
Any ideas?
Pete
1539 11 3- wayward
- 12 posts
- edward
- 7863 posts
- wayward
- 12 posts
- edward
- 7863 posts
I don't think that's the same thing. I don't get these on a stock Houdini 20.5.278 install so I think something in your environment is perhaps doubling out the search path leading to things being loaded twice. Try:
- Make sure Houdini is NOT running anywhere
- Rename your $HOME/houdini20.5 directory to something else
- Start Houdini again
- ResilientPictureCompany
- 109 posts
- edward
- 7863 posts
- michail kuznetsov
- 3 posts
waywardWindows 11 or 10 ?
Any ideas?
Pete
- spiderbr
- 5 posts
For me same message!
Windows 11!
Windows 11!
Edited by spiderbr - July 22, 2024 10:33:41
- edward
- 7863 posts
- michail kuznetsov
- 3 posts
spiderbrIn maxon forum problem fix. no use houdini env instead of this .json file in packages folder
Windows 11!
- guillaumebile3
Bonjour à tous ! nouvel sur Forum.
Hello everyone! New to the Forum.
After some checks, I believe these messages are due to MOPS in the file . ENV
Try to delete it to see, it worked for me but I immediately put it back because I just came from C4D and you know what the MOPS mean for a C4D user
I hope it works for you if you can do without MOPS.
Greetings!
wayward
Any ideas?
Pete
wayward
Any ideas?
Pete
Greetings!
- toadstorm
- 362 posts
MOPs can't cause HDK errors. The error is likely due to some other plugin that you have in the C:\Users\XXX\OneDrive\Documents\Houdini_Plugins path. Remove that path from HOUDINI_PATH and the error will likely be fixed.
