Nested dictionary in VEX showing unexpected behavior.
   Views 663   Replies 4   Subscribers 0
Good Day Community.
I was under the impression that in VEX, variables are passed by reference.
Then, can anyone please explain why it's not the case in the following example, ie: once b is passed to a, any further updates to b is not reflected in a's reference(or copy) of b?
dict a = set('name', 'A');
dict b = set('name', 'B');
dict c = set('name', 'C');
a['next'] = b;
b['next'] = c;
printf(a['name']);                        // Output 'A', as expected;
printf(a['next']['name']);                // Output 'B', as expected;
printf(b['next']['name']);                // Output 'C', as expected;
printf(a['next']['next']['name']);        // Output nothing, expected output 'C'.
An equivalent example in Python, with expected output would be:
a = dict(name = 'A')
b = dict(name = 'B')
c = dict(name = 'C')
a['next'] = b
b['next'] = c
print(a['name'])                        # Output A, as expected;
print(a['next']['name'])                # Output B, as expected;
print(b['next']['name'])                # Output C, as expected;
print(a['next']['next']['name'])        # Output C, as expected.
Thank you, for any advice/insights you may provide.
Edited by aeonzeon - Sept. 12, 2024 14:44:44
aeonzeon
they are passed by reference to functions when used as arguments
but assignment using = will pass evaluated value
Then, is there anyway/noway to achieve in VEX the same behavior as in the Python example above?
Thank you.
aeonzeon
Thank you.
If you change the order of assignment
b['next'] = c;
a['next'] = b;
Ah! Right!
Thank you.
