I'm new to Houdini Engine for Unity, diving head first into the Docs, I can't seem to figure out how to get the Curve Editor working.
The Docs mention two methods to create a Curve Asset:
Curves can be created for editing in 2 ways:
Menu - Create a new editable Curve SOP via HoudiniEngine ▸ New Curve Asset
HDA File - Load an HDA containing a Curve SOP node whose name is set in the Editable Nodes list (Deprecated in Houdini 19).
When I use the first method, it creates a Curve Asset but the Editor and "green lines, white dots" that I'm expecting to see aren't visible.
So, I used the second method, created a basic HDA that expects a Curve Input, imported it in Unity. The HDA is imported correctly, but when I try to use the custom Curve Asset created in the first method in the HDA parameters, the Curve Editor still isn't visible. I know the Curve exists because the Geometry output is generated at the one and only point that exists in the Curve Asset.
But I can't add any more points or edit them because the Editor is invisible.
Yes, I'm using the Curve 1.0 version SOP, not the unsupported version.
Does anyone know how to fix this?
Curve Editor doesn't appear in the Unity Editor
2293 13 2- Varun_studentaccount
- 14 posts
- 14 posts
- dpernuit
- 550 posts
The issue was likely caused by some of the plugin's URP/HDRP shaders not being present in the plugin's package that ships with the installer.
The github version of the plugin had those - but they were not in the installer.
I fixed the unitypackage in H20.5.340 - so you should no longer need to modify the shaders.
- 14 posts
Hello, thank you for fixing it!
Do you know how I can update the plugin though? Because I can't find an option in the Houdini Launcher.
Also, I have a separate bug to report with another HDA that is likely related to this issue, should I continue with it on this post, create a new post or message you?
- rvinluan
- 1275 posts
You should be able to upgrade the Unity plugin in the Houdini Launcher:
- In the Launcher, select
Engine Plug-Ins
on the left hand side. - If the Unity plug-in is already installed, then you should see an installed entry for it. Click on the gear icon menu button to the right of the entry and choose
Modify
. - In the Unity Plug-In Modification Dialog, change the version in the
Version
field and then clickModify
to proceed with the upgrade.
I recommend posting in a new forum thread since it's a separate issue. A new forum thread will also have more visibility to the user community.
Rob
- 14 posts
rvinluanHello Rob!
change the version in the Versionfield and then click Modify
I did exactly that, however, I don't find the option for the H20.5.340 version that dpernuit mentioned in his answer. I have installed the 20.5.332 version for now, I will let you know if it works.
Thank you for your attention to this issue
- 14 posts
Varun_studentaccountIt still isn't working right out of the box.
What's different from last time is that:
1) The Curve Editor DOES show up when I create a new Curve asset, however, when I add a single point to the Curve, the Editor goes into an infinite loop of printing errors and warnings (screenshot) which slows down the Engine, and after that, it doesn't let me add or edit points for the Curve with the Curve Editor
2) None of my previous HDAs are now working, the Geometry doesn't load. Previously, with the fresh install, it would at least load the Geometry with the Pink default Unity Shader that indicates a missing Material.
- 14 posts
Varun_studentaccountWell, even that stopped working. I think I will use my own version of the 20.5.278 Plugin for now :/
I even tried the GitHub version on this link: https://github.com/sideeffects/HoudiniEngineForUnity [github.com]
But even that doesn't work right out of the box.
Edited by Varun_studentaccount - Sept. 14, 2024 11:05:54
- dpernuit
- 550 posts
It seems like there is some confusion here:
The fix for the shaders was in 20.5.340 - so any version after it has the shaders - previous won't.
So by installing 332 - you got a version before the fix - back to the original problem of missing shaders.
Just tried on my end by installing 20.5.359 today - and got no issues on my end with curves (tried unity2022.3 - but I doubt this issue would be related to Unity versions)
- 14 posts
dpernuit
As I previously mentioned, neither the Launcher nor the SideFX website, nor the GitHub link let me install 340
I tried it with 357 too, the Houdini Launcher lets me install 332 of Houdini but 357 of the plugin, so Houdini Engine doesn't work with 332 because of the mismatch. 278 and 332 are the only versions where I have matching versions available.
Edited by Varun_studentaccount - Sept. 16, 2024 18:05:13
- 14 posts
- 14 posts
dpernuit
Hello, so I checked today, and the Launcher had matching versions for the Houdini Daily Build 20.5.362 and the Unity Plugin 20.5.362
I installed both and tried today and the Shaders worked right out of the box, however, the Curve Editor does not work right out of the box. The Curve Editor UI does not pop up when a Curve is created.
Thanks for your time
EDIT: I copied the Shaders from the 362 Plugin into my working version (where I managed to make the Curve Editor work) of the 278 Plugin and now the Default Shaders also work in 278.
Edited by Varun_studentaccount - Sept. 19, 2024 10:57:42
- zhouyustudio
Varun_studentaccountI have the same problemdpernuit
- zhouyustudio
