when I use the Layout node to populate my scene, is there a way to edit or completely change a material?
When I use the EditMaterialNetwork, it loads the material, allows me to edit it, but the change doesn´t show up in the rendering. Sometimes, EditMaterialNode has a warning flag with a meesage telling me that authoring to an instance Proxy is not allowed.
When I try to rewrite the old material to a new one, the AssignMaterial node fails with messages about not being able to make the new material binding to an instance proxy.
There must be a way though to change or overwrite materials for instances.
Thanks in advance.
Ivan
Solaris - Change or edit materials on Layout instances
3782 5 2- ivanmalek
- 143 posts
- PaoloGiandoso
- 60 posts
- 7990 posts
ivanmalek
There is not. Primitives below instances are write protected--they cannot be changed.
The scene could be authored differently, such that materials on instances are themselves instances of a primitive that contains a material with an 'inherits' arc. This would allow for edits on the material that they inherit from. Another option is for the material assigned to the prototype not to live under it. This would allow for edits, since it is not instanced.
- blakshep
- 77 posts
I had same issue problem is you should able to edit your prototypes and you instances should get those changes, but for some reason your prototypes also come in instance from layout tool.
Just put down configure primitive node and set your prototypes to not instancable and you can modify them freely.
It is very confusing how it is setup at moment...
- suemarisauer
- 8 posts
- AnimGraphLab
- 63 posts
blakshep
You might be looking for Edit Prototypes LOP [www.sidefx.com] node. Changing material via Material Edit LOP [www.sidefx.com] also worked for me (look at second GIF).
In the example below, I've used Split Point Instancer LOP [www.sidefx.com] into another point instancer to apply changes only to specific prims. I guess there's a way to do it without splitting Point Instancer, haven't tested.
You can use Merge Point Instancers LOP [www.sidefx.com] to combine point instancers into a single point instancer. I didn't show it as it was out of this thread's scope.
Assign different material (
[0-50]
is a syntax to select instances from 0 to 50 i.e. not all instances):Material Edit:
Edit: to debug what will be written to USD file: RMB on the node -> LOP Actions -> Inspect Active Layer.
Additionally, scene graph tree prim metadata and other things..
Edited by AnimGraphLab - Sept. 16, 2024 02:12:23
