Render to disk Karma XPU render with CPU only
   261   2   1
I wanted to render an short sequence on my single comp instead of sending to frm but I've noticed that it is rendering with CPU only and not with GPUs. Rendering Karma XPU in view port works perfectly fine, both GPUs used but if I start render to disk it is using CPU only and everything seems to be properly set to use Karma XPU and not CPU.
Any ideas?
is it possible that I'm only one seeing this?
Mirko Jankovic
I have the inverse problem on the renderfarm with Karma XPU :p
