Clay Milling Approach
   277   3   4
Hi everyone,
I'd like to try making a setup that looks like clay milling machine: Your text to link here... [www.youtube.com]
Looking for ideas on how to approach this task. Not sure where to even start. I'm thinking of a simple object first, like cutting out a "T" letter out of the box of clay. See a sketch attached.
All ideas welcome!
Edited by psychoboy852 - Nov. 11, 2024 06:45:38
Do you have experience with CNC Machining Milling ...??
easiest method its Boolean , with groups you can make Chipping effect.
then You must think about About -steeping ,roughing and finishing....... OJ OJ ...
Edited by cncverkstad - Nov. 11, 2024 10:38:23
Conservation of Momentum
cncverkstad
Hi, thanks a lot for the info. It looks like a really good solution, I'll try to re-create it. I could probably transfer the attribute for the wall that's been trimmed and use it for shading.
If you want to see the boolean method in action, there's a sample scene posted in this post [www.sidefx.com].
