playing with gausian splatting. I can import the point clouds with their custom attributes and edit them. But houdini exports .ply files as ASCII.
gply also converts them as ASCII. It has a parameter for ASCII export but not for binary? Is there any other way?
gply or any other way, can i export binary .ply files?
2542 7 3- vkucukemre
- 3 posts
- DavidRhodes
- 4 posts
I am also trying to work with Gaussian Splats in Houdini, encountering the same issue. What I'm trying now is to convert the ASCII ply (from Houdini) to binary using pyply [python-plyfile.readthedocs.io].
This seems to correctly encode the data as binary, but the SIBR Viewer cannot open it. It appears Houdini adds some invalid header data which causes the following error:
If you delete the bad header data, the viewer will launch, but then crashes with a new error:
What's interesting to note is that if you load the original ply into a file sop, save it back out with a file sop, then convert to binary, the file size is the same (according to windows explorer).
If you find a solution, please share!
[SIBR] ## ERROR ##: FILE C:\projects\gauss2\SIBR_viewers\src\core\graphics\Shader.cpp
LINE 116, FUNC sibr::GLShader::init
OpenGL error 0x0501 (1281) GL_INVALID_VALUE at C:\projects\gauss2\SIBR_viewers\src\core\graphics\Shader.cpp:116
[SIBR] ## ERROR ##: FILE C:\projects\gauss2\SIBR_viewers\src\projects\gaussianviewer\renderer\GaussianView.cpp
LINE 541, FUNC sibr::GaussianView::onRenderIBR
A CUDA error occurred during rendering:an illegal memory access was encountered. Please rerun in Debug to find the exact line!
- dobromirpetushev
- vkucukemre
- 3 posts
Only solution i've found so far is using the Unity Plug-in by Aras-p...
https://www.youtube.com/watch?v=YtjvfRAEJE0 [www.youtube.com]
https://github.com/aras-p/UnityGaussianSplatting [github.com]
Edited by vkucukemre - Dec. 20, 2023 10:08:57
- DavidRhodes
- 4 posts
- maxbel
- 39 posts
Hi everyone,
Resurrecting this topic given we're having some issues exporting a .ply sequence from Houdini to be read into SIBR.
Dragging this .ply into the open SIBR viewer with a camera.json file in the same folder also crashes the program with this error message :
I'm currently using the GSOPs v2.0.0 package and exporting as seen in the screenshot below. Has anyone found out how to solve this?
-- INFOS --: Initialization of GLFW -- INFOS --: OpenGL Version: 4.6.0 NVIDIA 560.70 Test (view create) took 134 -- INFOS --: Interactive camera using (0.009,1100) near/far planes. -- INFOS --: Loading lookat path. -- INFOS --: - Playing ## ERROR ##: FILE D:\Projects\InfiniteRealities\GaussianSplatting\sibr_core\src\projects\gaussianviewer\renderer\GaussianView.cpp LINE 636, FUNC sibr::GaussianView::onRenderIBR A CUDA error occurred during rendering:invalid configuration argument. Please rerun in Debug to find the exact line
Edited by maxbel - Dec. 10, 2024 08:58:12
- maxbel
- 39 posts
- DaRhodester
Hard to debug without data, but does the exported .ply load into other applications successfully (e.g, SuperSplat, Postshot, Unity, etc.)?
One thing that concerns me about your setup is a missing gaussian_splats_import node. The export SOP expects attributes generated from the import SOP (which file SOP does not provide).
