Simplest Payload Setup
   262   3   0
Mmmm feeling a bit silly but can't get an expected behaviour and not sure why. Without going down the component builder hda route, I want to in the simplest way possible create a payloadable usd asset, with bounding box preview.
Using Houdini 19.5 (at work)
I have a model.usd and material.usd file, that I am sublayering together and write out as an asset.usd
When I use a reference LOP to bring in my asset.usd, and set node to payload, the asset unloads. As expected there is no bbox preview. All info about this points to using a node called loftpayloadinfo to generate bound info.
When I append this node below model and material sublayering, write out my asset, reference it back in... Same result. Also I do not see any bbox metadata in the usd file. The node did nothing.
However using that new reference node, if I set it to payload, and append a loftpayload below this, I now see a bbox (strangely being created from an asset not loaded?!)
If I write this out as payload.usd, and I once more reference in this new file, with it set to either "reference" or "payload" in the reference type field, I get payload behaviour with bbox! Is that correct? (perhaps that's how it means to be? i.e i'm referencing a payload now so it's behaving like one?). Seems a bit confusing I can no longer choose load behaviour as reference, or payload, on the node that behaving exactly like that in just the previous step.
If that all sounds correct, How can I set up the bound info directly when i'm sublayering my model and lookdev together to prepare my asset.usd? I suspect it want's a root prim to write the metadata to that wont be there with I reference, so that's why it doesn't work?
Interestingly to help demonstrate, at home (H20.5) ive tried to add an example file to showcase my confusion. However there i hit another issue. If I set any reference to payload, its doesn't change to one. That sounds broken. (file attached)
Edited by revilo3d - yesterday 00:07:11
payloadTest.hipnc (199.8 KB)
From your description I can't quite tell what stages of your workflow are asset construction (payload unloading/loading not relevant so much), versus using your asset in a shot or scene (with payloads loaded or unloaded).
Hopefully the attached file helps, just run the two rop nodes from left to right.
payload.hipnc (119.3 KB)
Thanks Antc,
Appreciate the file, and settled on something pretty similar! Interesting use of the empty sublayer node. I see it setting load payloads to off, and controlling that for the whole stage?
Why does simply setting a reference node to payload for the usd file still do nothing. I'm very confused about that.
My expection is with viewport payloads off:
Reference > ReferenceType > Reference File = A Reference (not treated as a payload)
Reference > ReferenceType > Payload = An unloaded Payload (and turned on and off using viewport masks)
Seems like one can't have a usd file that supports acting behaving as either reference or a payload. Shouldn't payloading purely be a loading behaviour when we call on the usd file?
Inside the usd file it switches between:
prepend references = @D:/downloads/geo/sphere.usd@</Sphere>
prepend payload = @D:/downloads/geo/sphere.usd@</Sphere>
But both show just the bounds until I load payload :S
revilo3d
The behavior I'm seeing from Step 2 in the file I attached is that when the reference lop is configured to "Payload File" it's possible to load/unload in the viewport. Sorry if I'm misunderstanding.
Edited by antc - yesterday 23:15:49
