ROP Fetch TOP - how to use ROP Node Configuration?
   Views 666   Replies 4   Subscribers 0
- I have a ROP Geometry Output SOP set to Render Frame Range 1|100|1
- Fetched it using ROP Fetch TOP
- set FramesAndBatching/EvaluateUsing to ROP Node Configuration
it results in 1 workitem
1. How do I make it actually using the range from my ROP?
- tried adding float3 parm of the same name as on ROP Fetch TOP (range1, renge2, range3) on top of ROP's default (f1, f2, f3), but that didn't make any difference
2. is it possible to also add other settings like All Frames In one Batch to the ROP itself? Is this ROP Node Config actually configurable?
- I tried to look for TOP Related Node Properties, but there is nothing related to Frames and Batching
It's very important for settings to live on the ROP rather than be scattered in all the possible TOPNetworks that may fetch the ROP, especially the Range to avoid node produced one result when cooked from node itself (Save To Disk) and another when cooked from TOPnet
H20.5.487
Edited by tamte - Feb. 1, 2025 14:46:00
CG Supervisor
Framestore, NY
as a workaround using expressions in the range on ROP Fetch TOP seem to work
ch(chsop('roppath') + "/f1")
ch(chsop('roppath') + "/f2")
ch(chsop('roppath') + "/f3")
this also allows the "roppath" to be dependent on workitem attributes
I'd still be nice to know why the ROP Node Config creates just a single workitem for the whole range
Edited by tamte - Feb. 1, 2025 15:02:11
CG Supervisor
Framestore, NY
tamte
That mode exists specifically for use with ROPs like the FBX, Alembic and sometimes USD where the frame range isn't known until the ROP actually cooks. For example, the FBX ROP can be setup to load a frame range from an FBX file. In that case the only thing TOPs can do is create a single task that cooks the target ROP exactly as-is, and waits for it to cook over what frame range it wants.
For ROPs with frame ranges defined statically using parameters it's possible to use a ch-ref.
the CH references are ok, but still require a setup, it's be nice to be able to just add TOP related parameters on the ROP itself that ROP Fetch could inherit
that way the same ROP fetched into one or multiple TOPnets can produce the same result as it's configured without User having to think about what needs to be channel referenced
of course this is just a workaround to seemingly not being able to fetch configured TOP node statically https://www.sidefx.com/forum/topic/99586/ [www.sidefx.com]
since that would also allow to have config already on the TOP node which is part of the setup and just fetch to a bigger TOPnet to set dependencies
CG Supervisor
Framestore, NY
That should be possible, e.g. by having the ROP Fetch evaluate the frame parameters on the ROP and use the values found there. Please log an RFE.
