Parsec and virtual displays
   Views 5475   Replies 7   Subscribers 2
Now when we're in the age of working remotely I have tested parsec and It's pretty good. I can even animate and get decent playback.
The problem came when I tried the virtual displays setting. When I turn it on Houdini crashes on startup. All other apps I have tried seem to work.
Might be a GPU issue? I use Parsec all the time with Houdini (windows) and it works great.
madebygeoff.com
Did you use virtual display?
I get this same problem every time using virtual display driver.
Try adding this to ENV file in your documents folder under Houdini , it worked for me.
HOUDINI_USE_HFS_OCL = 0
Drewzee
You have perfectly solved my problem. Thank you very much.
I used Parsec Virtual Display. When I remotely controled Houdini, the program crashed.
But after I added this line of code to the .env file, Houdini can now open normally.
Oh wow. Thank you so much. It worked splendidly!
Have a great day.
Oh wow thx @Drewzee! Awesome
Hello there.
We're encountering this issue with our new 5090 GPU, even with the houdini.env properly set. Is there any trick for this new nvidia serie ? It's working correctly on 4090.
