Primitive selection on HDA
   Views 619   Replies 3   Subscribers 1
Hi!
I am creating an HDA with 0 input, it reads/works for another geometry from a merge_object node inside of this HDA.
and I would like to select some primitives with a string parameter with an "Action Button":
import soputils
kwargs['geometrytype'] = hou.geometryType.Primitives
kwargs['inputindex'] = 0
soputils.selectGroupParm(kwargs)
but it fails because it is asking for an input.
there is another way to select the primitives? for a geometry that does not come from an input.
Gerardo Castellanos
www.gerardocastellanos.com
kwargs['noderefparm'] = "the path to your merge object's parameter'
Edited by raincole - March 10, 2025 08:47:52
Hi @raincole.. thanks
I tried this:
import soputils
kwargs['noderefparm'] = kwargs['node'].node("ObjectMerge").parm('objpath1')
node("ObjectMerge")is my ObjectMerge Node.
but it does not work
Edited by Gerardo Castellanos - March 10, 2025 09:11:41
Gerardo Castellanos
Oh... sorry, my mistake.. it works.. THANKS YOU A LOT!
Gerardo Castellanos
