Hi, before I install, I want to ask if the 9.1 version is also for houdini apprentice HD users?
The 9.0 license server said the license will last until 2037 or somewhat like that, but as I heard, the licence server for 9.1 will say it will only last until the end of february 2008 ?
thanks in advance,
frank
Is 9.1 for HD users?
6972 8 0- blindcat
- 28 posts
- Joe
- 483 posts
- blindcat
- 28 posts
- mark_visser
- 71 posts
- JColdrick
- 4140 posts
- mark_visser
- 71 posts
Yup, I'm running 9.1 fine (with 9.1 license server) with a regular apprentice license. My HD license is only 9.0 (I double-checked at license.sidefx.com).
License server version: 9.1.124
Installed licenses:
LicID Platform Product Ver Avail Expiry
b12821f4 Generic Houdini-Master-NonCommercial 9.1 1/1 11-mar-2008
+.+.+.+ rincewind (license known to: rincewind)
fbecc690 Generic Houdini-Master-NonCommercial 9.0 1/1 01-jan-2037
4847d752 Generic Render-NonCommercial 9.1 1/1 11-mar-2008
646d625e Generic Render-NonCommercial 9.0 1/1 01-jan-2037
1856b84d Generic Houdini-Apprentice-HD 9.0 1/1 01-jan-2037
(expired licenses removed for brevity)
Installed licenses:
- JColdrick
- 4140 posts
It just looks like you need to login with your email and password to get the new licenses, but you say this doesn't work. I'm not 100% the account is for HD customers too, but try emailing LicenseManager at sidefx dot com and let them know your specifics and they should straighten things out.
J.C.
J.C.
John Coldrick
- probbins
- 1145 posts
- rafal
- 1455 posts
you should not need to return any licenses; the 9.1 licenses are usually an upgrade, rather than a brand new license.
what may have happened, is that you purchased the entitlement to 9.0 before, and redeemed it after the upgrades to 9.1 were issued. Because at the upgrade time you had an entitlement and not the license, the upgrade could not be issued. I've seen one similar case, and, although still hypothetical, it is the best explanation I could come up with.
The best thing is to email support describing this problem and they should be able to issue an upgrade manually. Be sure to supply the user name so that they can identify your account.
Rafal
Rafal
