Please how can i render with prman directly in mplay?, i follow the tutorial at the odforce.net (prman setup) everything is ok, i hit render from the output node and its work property, but if i want to render directly on mplay, i have to install one of the plug ins that come with proto_install command, after that when i hit render again it display a c++ error and in the houdini console it shows
“D04001 {WARNING} DspyName couldn't find requested driver C/DOCUME~1/NECROB~1/RI_SHA~1/d_houdini.dll (No se puede encontrar el módulo especificado.)
R90011 {SEVERE} Can't open display image ip”
How can i do? please help me!!!!
Thanks.
Prman render in Mplay with proto_install didnt work
17925 16 1- Alejandro Echeverry
- 691 posts
- Pagefan
- 519 posts
- 691 posts
Abd The c++ error is
Microsoft Visual C++ Runtime Library
Runtime Error!
Program C\Archivo…
R6034
An application has made an attempt to load the C runtime library incorrectly.
Please contact the application's support team for more information.
Aceptar
Runtime Error!
Program C\Archivo…
R6034
Aceptar
- edward
- 7899 posts
- 691 posts
that s not the problem, im working in a 32 bit windows plataform.
Please help me!!!
Please help me!!!
- Pagefan
- 519 posts
- 691 posts
Yes, when the command line ask me if i want to do a test render i let it do that, but it didnt modify directly the rendermn.ini, it put a rendermn.ini file in MyDocuments windows folder, and i manualy copy the line in that rendermn.ini to the correct rendermn.ini located in the renderman pro server instalation, i copy that line at the end of the rendermn.ini.
- 691 posts
- Pagefan
- 519 posts
- iaiotom
- 7 posts
- edward
- 7899 posts
- iaiotom
- 7 posts
- 691 posts
The proto install driver only works in the VC7 version, in the VC8 didnt work it put a c++ error why?
it should work on both versions.
- Pagefan
- 519 posts
- emiljojo
- edward
- 7899 posts
- hewen0112
