Is it possible to create a SOP with inputs like Dop/gravity?
The idea is to separate the input geometry as one surface (which will be displaced inside the Sop) and
several other geometries which are used to calculate the displacement.
Thanks.
HDK - Sop several separated inputs
3752 2 0- burnie
- 23 posts
- Gerome
- 85 posts
I have nt seen how looks the DOP gravity. But if I understood your question,
you want to connect different geo to your SOP. Let say A and B
You have to add the number of inputs you want, when you declare your OP
void
newSopOperator(OP_OperatorTable *table)
table->addOperator(new OP_Operator(“sparticle”,
“Simple Particle”,
SOP_SParticle::myConstructor,
SOP_SParticle::myTemplateList,
1, // Min required sources
2, // Maximum sources
0));
then you loop through and you collect the GDP of each input
src = ( GU_Detail *)inputGeo(current_obj, context ))
If it answers your question I go into details.
void
“Simple Particle”,
0));
- burnie
- 23 posts
Thanks for the reply.
What I was looking for is a way to create a Sop with two input-boxes, one that takes one single input and another that takes an arbitrary number of other inputs.
The idea is to have a grid as the single input (which will be displaced in the Sop), and use the other inputs to calculate the actual displacements. I sent an email to support and found out that this is apparently not possible. It's only possible to do it the way Gerome described.
I guess instead I'll have to label the inputs somehow to know which one is the grid and which others are standard geometry. Any ideas on how to do this in a smart way?
