Hi!
I want to create a cloud of balloons (huge one) all attached to the ground via strings. I don't want to model each and every one of them seperately, so I'm looking for a procedural approach. Anyone has an idea?
Thanks in advance,
Phong
Cloud of Balloons
13040 19 1- Phong
- 65 posts
- Phong
- 65 posts
- probbins
- 1145 posts
- probbins
- 1145 posts
- Phong
- 65 posts
- Phong
- 65 posts
I tried the approach with Add and Group sops, but this way I still got to define a lot of things manually. Instead of copying to the points on a sphere, I used IsoOffset (as fog volume) and copied my dummy balloons into that volume. Now how do I get a curve generated for each balloon which is connected to the balloon on the one end and to the ground on the other side??
- circusmonkey
- 2624 posts
- Phong
- 65 posts
Well I haven't thought about that so far, I assumed the balloons have neither an upwards nor a downwards tension, so they're all floating in the air. I've even not planned to make them moving, I just try to figure out how to create strings from the ground to the balloon for hundreds and thousands of balloons - and then I will stark making them dynamic
- circusmonkey
- 2624 posts
- Phong
- 65 posts
- Phong
- 65 posts
- 8845 posts
- jrgauthier
- 243 posts
Hi!
I could not help to make those balloons move and float around.
I tweaked tamte's exemple file…
:wink:
:wink:
JR Gauthier
Character Animation & Design
www.turboatomic.com
http://www.vimeo.com/user2847970 [vimeo.com]
www.turboatomic.com
- asnowcappedromance
- 512 posts
- 8845 posts
asnowcappedromance
…could you please explain why you used the “skip to the Nth point” with an increment value of “$N/2” in the add SOP ?…
imagine you have set of points and each of them has its point number
let's say 10 points with numbers 0,1,2,3,4,5,6,7,8,9
then Skip every Nth point means:
it will connect every point with point which point number is Nth from it
so if N is 2 it will connect points:
0,2,4,6,8
and
1,3,5,7,9
if N is 3:
0,3,6,9
and
1,4,7
and
2,5,8
if N is 5:
0,5
1,6
2,7
3,8
4,9
in my example there is a set of points representing baloons
and set of points representing anchor points on the ground
let's say 10 baloons and 10 anchors
then merging them together will give me 20 points with point numbers 0-9 for baloons and 10-19 for anchors
then using Skip every Nth point set as $N/2 means:
$N is total number of points (20)
$N/2 == 10
so it will skip to 10th from each point and connect them
0,10
1,11
2,12
3,13
9,19
so it will connect each baloon with corresponding anchor
- 512 posts
- Phong
- 65 posts
Tamte that was awesome!
Now I want to tie them all together (like they're anchored about all to one point), so I scaled down the anchor points so they form a tiny area on the ground. All points are still connected by straight lines, but how do I get those lines to look like wires again without having too simulate?´
Thanks in advance!
Phong
Thanks in advance!
Phong
- 8845 posts
- Phong
- 65 posts
- 512 posts
if you increase the subdivisions of your wires with for example a resample SOP, you could also play with the spring SOP to move those wires smoothly.
there's a nice sidefx tutorial about seagrass that you might check out:
http://www.sidefx.com/index.php?option=com_content&task=view&id=944&Itemid=257 [sidefx.com]
