No icons in Houdini
27313
23
6
MikeTaylor
Jan. 19, 2010 8:50 p.m.
queglay how do i enter that code? sorry im pretty new to macs.Run the application /Applications/Utilities/Terminal
That's how you start up a “UNIX shell”. That command is a unix command. Just past it in and hit return. You will be asked for your password.
Note that your username is the name that's beside the house icon on the left side of the Finder.
Hope that helps!
Jan. 19, 2010 9:48 p.m.
thanks. i get the error, no such file or directory. i can't seem to find that path so im not sure where to refer it to.
https://openfirehawk.com/ [
openfirehawk.com ]
Support Open Firehawk - An open source cloud rendering project for Houdini on Patreon.
This project's goal is to provide an open source framework for cloud computing for heavy FX based workflows and allows end users to pay the lowest possible price for cloud resources.
MikeTaylor
Jan. 20, 2010 8:19 a.m.
queglay thanks. i get the error, no such file or directory. i can't seem to find that path so im not sure where to refer it to.The ~ refers to your home directory. So ~/Library/Preferences/houdini would be under your home directory.
Anyway, just try installing the latest version of Houdini from the link I gave above and see how it goes.
RonTheDon
April 17, 2010 5:02 a.m.
I have had this problem many times so far as well (on Vista, Win7 and with Houdini 9.5 and 10 versions).
One minute everything works fine and then you restart Houdini and all the icons are blank/gone.
I've always wondered if it was a challenge set by Sesi on our memory
However, in my cases it has always been a case of a corrupted SVGIcons.cache file, which on Windows is in your "Users\\Documents\houdini\config\Icons"
Deleting/renaming it and running Houdini forces a rebuild and so far has fixed it for me
cheers
Ron
