Recovering Lost Points
   3635   2   1
can any one help me to recover all the points i lost after i reshaped the curve obj as attached.
Steve
fly_reshape_withgrid_151-3.hipnc (974.9 KB)
Hi Steve,
now I understand which scene are you talking about in your PM.
I still don't understand which points are you referring to.
If you need some points inside the poly face, try using a Divide SOP, uncheck “Convex Polygons” and check “Bricker Polygons”.
If you just need the points on your profile curve as you had before the reshaping, try to assign the “Display/Render flag” at “back_to_your_flow” Null SOP.
Hope this help you with your problem.
Emanuele
www.leleberti.com
Lead Crowd TD @ DNeg London
________________
I guess my question was wrong.
My intention is to recover the grid in the reshaped curve or circle.
May be because i may need them to have points on the grid.
After you reshaped the curve the grid disappeared and left only outside curve. Can you help me how i can have the grid back as i had before you reshaped it. Idid tried your instruction but it did not working.
Thank you very much again.
Steve
