problem with the creep sop
   Views 3293   Replies 2   Subscribers 0
hey gang,
Ive been trying to use the creep sop to copy buildings onto a collection of surfaces that I created using a series of texture maps. the buildings look pretty good at a distance, but when you look at them up close they are all warped and occasionally have vertices sticking out at weird angles. I'm not sure how to correct this problem. is it that I'm not providing a good map? or is the creep sop not set up properly? or something I haven't considered. any suggestions would be great thanks.
realized it might work better if I supplied a photo
hey cargoyle ,
did you find a solulation i have the same issue been trying for while to fix it…
