hi all..
I'm pretty sure this is a FAQ, but my custom VEX SOP is called on the same thread for each point. Is there a way to inform Houdini that the SOP can be called on multiple threads?
thanks!
custom VEX multithreading
6611 7 1- david_aiken
- 86 posts
- Simon
- 2199 posts
- david_aiken
- 86 posts
Got it - thanks .
I was expecting a multi-threaded/single-threaded toggle in the HDK since this SOP should always run multi-threaded and benefits from as many processors as are available (it doesn't place a heavy load on them.. it just runs better). Is there a way to do this rather than setting a specific number of processors for each instance of this type on each box?
As a kludge i was thinking of changing the default number of processors in the type properties to 99, but it doesn't let me edit the channel settings. I'm using the “File:New Operator Type..” method to create the SOP. Maybe it wouldn't work anyway..
Out of idle curiosity, what happens if i create a hip on a box with 2 processors and throw it on boxes in the Amazon farm with 4 processors or 1 processor? In the former case i'm hoping that Houdini creates 2 processors .
I installed a skylight in my apartment… the people who live above me are furious!
- Steven Wright
- Steven Wright
- mark
- 2619 posts
david_aiken
Got it - thanks .
Choose the “1 per processor” setting, then it will create one thread per processor.
- david_aiken
- 86 posts
hmm.. perhaps i'm doing something wrong. I print the point number from within the VEX SOP c++ code and even when the number of threads is set to 4 or 1 per processor the point numbers are printed out in order each time. I'm running on ubuntu 9.10 64-bit, Houdini Apprentice 10.0.595.
btw - thanks for clearing that up Mark.. i posted at the same time
- Steven Wright
- Steven Wright
- david_aiken
- 86 posts
I tried using the standard VEX_Ops.C example using hcustom and had the same behaviour. Perhaps due to some misunderstanding on my part, but i've logged a bug. If anyone has this working please let me know.
- Steven Wright
- Steven Wright
- malexander
- 5199 posts
Do you have enough points in your model? VEX processes points in batches (256, I believe), so you'd need a significant number to see any threading benefit. Threading is also only worth it if the amount of work you're doing per-point is significant, otherwise it really has no effect (or could even slow things down).
- david_aiken
- 86 posts
