change attribute which is behind the back
4665 6 1- luoqiulin
- 306 posts
i need the grid's point feed back different value,when it's front or back from the line by vop!
for example, the line's normal is forward, and if the grid's points is ahead from the line,the grid point's normal is forward too, and if the points is at the back of the line, the point's normal is reversed!
the picture shows my mean, wish you tell me how can i do it in vop!
- circusmonkey
- 2624 posts
- 8839 posts
lets assume that you are taking that green vector as a direction from nearest point on the line
then you should be able to have access to that point's normal (yellow vector) from any of the green points as well
so just calculate dot product between green and it's corresponding yellow vector and if it is less than 0 just reverse green vector
- peliosis
- 175 posts
- luoqiulin
- 306 posts
- graham
- 1922 posts
- luoqiulin
- 306 posts
