Geo Light in H 11 is not working
   9296   21   2
Hello, World.
I've just started H 11 and tried Geo Light.
Even after i did set everything it seems not working properly.
My geo obj doesn't lid.
Can any one help me Please.
Steve
Hi Steve, can You provide a demo file to have a look at.
Martin
aplink
Steve
bro…
Here is the scene file.
Thank you very much.
And, whenever i render i got this txt message in my shell terminal.
" mantra(8232,0x10e010000) malloc: *** auto malloc: error: GC operation on unregistered thread. Thread registered implicitly. Break on auto_zone_thread_registration_error() to debug. "
Test_For_Geo_Light.hipnc (462.4 KB)
i don't have any errors here but the render is strange. but the reason is there are 4 lights in the scene and the only object in the scene , that could be illuminated is the geometry source of one geo light, that is on the exact same place. ad some other objects and hide the geolight source geometry or don;t render the light geometry
hope it helps
martin
Thanks very much for checking the file.
I have the same number of light including the geo light in the other scene.
I can clearly see the animated obj is lid and can be brighter as i crank up the intensity of the geo light in the scene view port.
But, when i render it i do not see the obj is lid up and the brightness of the obj is not controlled by the intensity of the geo light.
With or without the geo light i have the same rendered image.
But, I do see the big difference in this case only in the view port.
Even with the geo light, after i render it, i do not see any difference in brightness of the obj as i crank up and down the intensity of the geo light.
Can you help me please?
Hi, aplink!
Perhaps I'm wrong but I can't see any problems. If you want to control brightness of geolight you will need to tune the intensity of light. Also I can see that you want to illuminate the object which you use for geolight and your object looks very dark. I can explain this phenomen. It's simple. Your object does not get enough samples of geolight because this object is too close to the geolight. You can create copy of object and then you should reduce the scale of the object. You will see that your object looks more bright.
Alexey Mazurenko
I did make a copy of the obj and scaled much smaller.
Now, I can see some type of illumination but quite rough, meaning a lot of bright dots or noise dots on the obj, not smooth surface.
How can i make it smooth illumination, like neon sign tube.
Like the same lid or illuminated obj in the example scene at sidefx.com introducing H11 geo light. (tumbling and rolling obj on the stair case)
I did adjust light intensity and sampling quality, but no difference at all.
Can you help me further please?
I assigned the material for my obj in the geolight para.
I do not see any illumination at all, same as W/O geo light after rendered.
I also Check “ TRANSFORM INTO THIS OBJ” in the geo light para.
I have created a file for you. You can look its. If you need my comment then I'll write a little later.
test_for_geo_light.hipnc (385.6 KB)
Alexey Mazurenko
I checked it out.
Can you make it brighter with some shade and with same color to see clearer volume of the obj.
(Like more of 3 D object)
Thanks a lot
Can you help me further ?
Because the geo obj can not be brighter in my H11.
Thank you.
aplink
Can you make it brighter with some shade and with same color to see clearer volume of the obj.(Like more of 3 D object)
Sadly I can't understand your problem. If you need to “see clearer volume of the obj” you shall use contrasting light.
Good luck! I wish you success
Alexey Mazurenko
Thanks for coming back.
Have you seen the H11 video introducing H 11.
The lid objs are tumbling or rolling down on the stair case.
I believe they use geo light to make them.
Can you help me how i can achieve it.?
Thank you very much in advance.
Steve
I have attached a few versions of geolight.
Do you want to have the result that I attached below?
Alexey Mazurenko
Thanks,
How can i achieve that kind of geo light.
I can not do that with my computer (snow leopard).
Can you help me.
Hi aplink,
Here is an example. Sorry, I forgot to attach it.
geolight_A02.hipnc (930.1 KB)
Alexey Mazurenko
I checked your Hip file.
I do not see any good difference in between with geo light and without geo lgt (just having area lgt).
I also noticed that if i use different material, such as clay or basic material, instead of constant, I can not make the obj solid and smoothly lid by geo lgt.
I tweaked many different options, such as open gl base color and emitted colors and so on. I still can not make my obj like a neon sign tube color.
Can you further help me please?
Thank you very much again.
aplink
Here is the simple example for neon tubes. I have used glow after render.
geolight_A03.hipnc (817.0 KB)
Alexey Mazurenko
