Hello, is there a way to limit Karma's threads to all but one?
I saw other similar posts but it seems this control was moved somewhere else?
Karma CPU cores control
346 5 0-
- vopsop
- 5 posts
- BabaJ
- 2141 posts
- vopsop
- 5 posts
BabaJ
Under the tab 'Output' of the usdrender rop there is a parameter 'Maximum Threads' you can tick on.
Read the tool tip so you can set with a positive or negative number according how you want it specified.
Thank you, but which one is it for—the live preview in the viewport or the final render? I’m looking for the one that controls live previews in the viewport
- BabaJ
- 2141 posts
- vopsop
- 5 posts
- BabaJ
- 2141 posts
If under the drop down menu that you normaly choose a view and/or Karma CPU/XPU Storm etc., there is a side menu 'Render Settings'.
If you select 'Viewport Settings'....then bring up the Display Options:solaris panel with spacebar +D.
Then under the Render Tab select Karma CPU from drop down 'Show options for'.
Under another tab 'Basic' there is an 'IPR Reserve Threads' that might help you.
This is strange to me, I always thought IPR 'stuff' was part of the Mantra frame generation but not Solaris(usd).
But...it might be worth giving it a try as it is under Karm CPU options and not greyed out.
Edited by BabaJ - yesterday 07:28:36
