I'm setting up batch processing for a library of assets.
I have a primitive string attribute:
Bridge_Small_Dark_01
I need to procedurally extract the part of the string before "_Dark".
Using split it seems it only accepts singular symbols as a separator (eg "/"), I need to find a way to use the specific string as the separator.
Using "_" as separator and using + etc in split would not work since not all assets have the same number of words before "_Dark"
Also due to the way material library is imported and variants are implemented, I cannot just remove "_Dark" from asset names.
Using
s@name = split(s@name, "_Dark");
does not work. Is there another function I should be looking into?
VEX split, but using a string as separator, not symbol [SOLVED]
191 2 0-
- juricakrizanic
- 3 posts
- tamte
- 9088 posts
use re_split() [www.sidefx.com]
string s = "Bridge_Small_Dark_01"; s[]@split = re_split( "_Dark", s );
- juricakrizanic
- 3 posts
tamte
use re_split() [www.sidefx.com]string s = "Bridge_Small_Dark_01"; s[]@split = re_split( "_Dark", s );
Thank you Tomas! This is exactly what I was looking for!
