I was under the asumption that the following setup should render without any problems using Karma XPU but it only displays the volume at frame 1 in a Solaris Desktop as well as when I render it out using a render rop. The volume vanishes after frame 2. I haven't played around with Pyro in Houdini for quite some time and have only recently test rendered a fire WITH smoke which worked flawless. Now I am trying to render just flames using Karma XPU but for some reason I'm encountering the forementioned problem. What am I missing here?
Render problem of fire in the viewport as well as a render rop.
459 4 2-
- Farmeadow
- 30 posts
- Tanto
- 503 posts
- Farmeadow
- 30 posts
- Tanto
- 503 posts
- Farmeadow
- 30 posts
