image sequence sprite
3694 2 1- poppy
- 16 posts
- gosch
- 8 posts
the way to do this is to create custom string attribute for every point of your particle system, that will override path to texture in sprite shader. Using expressions you can control, from what directory and what exactly texture will be loaded for every sprite at current frame
See the attached file, it will become clear
- poppy
- 16 posts
