Sprites
   6550   4   0
I want to render sprites with the Mantra Sprite Procedural shader.
If I render with the ‘old’ H8 Mantra ROP , the sprites render fine.
But when I render with the H9 Mantra ROP, I don't get any ‘alpha’ channel…
What am I doing wrong?
Using Houdini 9.0.795, windows xp, not so bad computer.
thanks,
bern
sprite_trouble.hipnc (458.6 KB)
Try using a VEX Layered surface SHOP for your sprite and set the texture map to Diffuse + Alpha.
I had the same trouble when using the Decal SHOP in H9.
www.alan-warren.com
Hello Alanw,
I'm using a Vex Layered Surface (see attached hip) and set the texture to ‘diffuse+Alpha’, but the problem is still there:
Mantra 8 renders fine, Mantra 9 does not…
thanks again,
bern
I only messed with the H9 Geometry object in your scene. I moved where you were calling your procedural to the Geometry Tab and put your material in the Shader Tab and that seemed to fix it up.
sprite_trouble_176.hipnc (921.2 KB)
www.alan-warren.com
Thanks Alanw.
Works great now….
bern
