After installing H9.1.124 i am unable to get the interactive rendering to display correctly, while launching a render to a file is all good. I am thinking it is a graphics card issue but would love more input. Below are a series of images showing the results of rendering form different places for a test scene i made.
System: XP pro service pack 2
2x AMd 244 processes
2.0 GB RAM
Graphics: 3D Labs Wildcat Realizm 200
I have also attached the hip file note it uses included materials in there default install locations.
Thanks for your time
Karlos
Pic1 - mplay launched from bottom right corner icon Left click to launch output.
Pic2 -mplay again mid render
Pic 3 Using render region note rendering correctly
Pic 4 Render to file.
Interactive rendering display problem
6135 6 0- snowman
- 6 posts
- jens_martensson
- 342 posts
- snowman
- 6 posts
- Ondrej
- 1081 posts
That's odd. Are the files correct when saved from the interactive mplay?
From the images, it looks like a problem with mplay displaying the image. In mplay, hit ‘d’ to open the Display Options, and click on the Video Card Options… button on the first tab. You might be able to find something in there which may help.
- malexander
- 5212 posts
- snowman
- 6 posts
Hi and thanks,
At this stage no luck, i tried setting mantra to 8 bit and set the display/video card options of mplay to best compatibility with no change.
What i did notice was if i start mplay independent of Houdini it all works correctly, it loads images and displays them with out trouble with the best hardware setting.
When i have opened mplay through an interactive render from houdini, it will not even display the same file as above and the icons words etc are distorted. I have included an image of that
Thanks again
Karlos
Thanks again
Karlos
- snowman
- 6 posts
Hi guys,
The latest installment i have found that if i change the quantization of mantra from 16bit float down to 16 bit integer the render progresses as you would expect.
I thought therefore i had hit a max level for my graphics card, but no ( at least to my limited understanding ), if i changed the quantization of mantra 32 bit float, we are all good again.
So i am happy again i can work around the problem, i am curious if someone can explain it to me.
Thanks again
Karlos
Thanks again
Karlos
