a question about porting the regular expressions to vops
   3567   2   1
Hi guys. I have a quick question. Let's say I have a basic expression which I want to recreate as a VOP Sop. It takes my line and turns it into a circle, so in the x it's sin($PT*2) and in Y - cos($PT*2). Now, when I recreate it in VOPs I find that if I use the same numerial value, 2 in this example, the result get about 10 times more dramatic then I expect. So in order for VOPs to give me a similar result I have to use something like .2 in VOPs. I tried a few other expressions and the outcome is always the same. Do you know why is VOPs doing it?
I'm attaching a simple example file.
Thanks a lot,
Luka
expreVsVops.hipnc (55.0 KB)
I'm pretty sure that's because expressions expect the argument to be in degrees, but vops expect them in radians..
eetu.
I actually tried to put in the Degrees to Radians vop into the network, both before my trigonometric expressions and after, and it still gives me the same results.
