Hi houdiniks.
I have set a hotkey to the Show Translate Plane ->XZ option in the transform handler that shows the XZ plane in the translate handler.
Quite useful, the problem is that the hotkey appears in the popup menu when I RMB on the handler but when I hit the key, j in this case, nothing happens.
Anybody have tried to assign a hotkey to this feature before?
Show XZ in Transform handler hotkey problem
3496 3 1- lisux
- 581 posts
- rmagee
- 1185 posts
- lisux
- 581 posts
rmageeOh! man that's another of the hidden shortcuts, is great, I don't remember if is included in the Houdini Spot book by craigm if not is a candidate to be included in a second edition.
There is an existing hotkey for this. Press Ctrl and click on the axis line that is the normal direction for the plane you want to limit yourself to. Press Ctrl and click on the center to go back to normal.
Thanks for the tip Robert
Un saludo
Best Regards
Pablo Giménez
Best Regards
Pablo Giménez
- lisux
- 581 posts
