placing vertices and making faces
3303 1 1- John_Laird
- 2 posts
- Simon
- 2199 posts
Poly count is easy. Just MMB on any node and it will give you the poly, point and vertex count. Getting it for a whole scene is a bit more involved though, currently you have to script it.
As for placing individual points, you'd have to use the add sop, to then join them together I'd go for the polyknit sop for starters.
Have a look at the curve sop too.
