hi, All.
I am wondering if there is a way to control the geometry transformation
by particle. I know copy sop is the one you can use,but how do you handle with multiple object(primitive groups) like shatter effect? Maya can instance each peace if you specify which obj you want to use with one particle system.
Thanks.
particle driven geometry transformation
5088 6 3- poppy
- 16 posts
- Allegro
- 696 posts
- stevecullum
- 112 posts
- jacob clark
- 665 posts
Hi Steve,
To be honest, this isn't the easiest thing in the world. If your lucky enough to just be shattering a pane of glass there's a simple workaround.
The Primitive SOP takes an equal number of of points and prims and matches prim number to point number. So if you have a point 1 and a prim 1, the prim will follow, and be transformed by the point.
And then to give the prim thickness, you can use a post op polyextrude.
Hope this helps.
cheers,
-j
Hope this helps.
cheers,
-j
- stevecullum
- 112 posts
- stevecullum
- 112 posts
- pbowmar
- 7046 posts
The trick is to birth the particles from the Primitive Centre (in the Source POP) using exactly the number of particles as there are primitives (use “npprims()” expression in the in Impulse birth) then away you go! Just copy the polys back onto the particles using the Primitive SOP.
Peter B
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
