How to change ui font type???
   8989   4   1
Hi all.
I want to change the default font type of the ui, as like as the size.
Now i change the font using the HOUDINI_UISCALE glob var, it's works but i like to change the font type if it posible, using any houdini's fonts.
I'm using houdini 6 under linux
Un saludo
Best Regards
Pablo Giménez
Copy $HFS/houdini/config/resources to $HOME/houdini6/confg/resources and make the new one writable. Now edit the one in $HOME to use the fonts and sizes which you want. The list of fonts available for this is in $HFS/houdini/fonts_gl.
Thanks Edward, i've tried it but it doesn't work.
I've made my own resources file in my $HOME/houdini6/confg/, then i sustitute for example:
DefaulFont System
by
DefaultFont Helvetica
reboot houdini but it didn't work, i change the font size too, but the same results
Any more clues, or i'm making any mistake???
Un saludo
Best Regards
Pablo Giménez
Try changing all the font names. Also make sure that your font name and size combinations are one of those in the fonts_gl directory mentioned above.
Such an old thread!!
