Its possible to import a parameter from other network? for example i define a color map string in a vex vop surface and export these parameter; then i create a vex vop shader and, how can import these parameter string that i define in the vex vop surface to use in the vex vop shader? it this possible??
i try with a parameter in the vex vop shader with the same name as the para meter from the vex vop surface and didnt work.
Thanks.
Import Parameter from other network type
2934 2 1- Alejandro Echeverry
- 691 posts
- Allegro
- 696 posts
- 691 posts
Its OK with a channel reference its absolutely possible, but i want to know if it is possible with a parameter from other context or network.
