Fluids Technical Evening Files
   3728   2   0
Any chance someone can post the files associated with the Fluids Technical Evening. Even the start files would be helpful for following along. Thanks.
I am not sure if those files are available. We will look into it. We did just post the smoke bomb example to the Exchange:
http://www.sidefx.com/index.php?option=com_wrapper&Itemid=8 [sidefx.com]
“This dynamic simulation of a smoke bomb integrates Houdini's Rigid Body and Voxel Fluid Dynamics. The smoke is emitted using information from the bomb canister to make sure that it emits in the desired direction while the canister spins through the air. The look of the smoke is derived from the material-based noise which sticks to the smoke as it moves. The final look is also enhanced with per-voxel motion blur.”
Thanks Robert. It would be great if the files are available, if not I'll just learn more building them myself! Also, thanks for the heads up on the smoke bomb example. I will check it out shortly.
