Fluid collisions - from inside
5278 5 2- tixilite
- 9 posts
- nas7ybuttler
- 29 posts
- keyframe
- 1533 posts
- vmur
- 82 posts
- IndyZoneCo
- 77 posts
You need a volume to create the collision geometry. A regular tube with a blasted cap is a only a surface, so it wouldn't work.very well with the default volume-based collision.
To get a better collision geometry for a cup, keep the top cap and extrude it inward so that your cup actually has some thickness.
Also go into the AutoDopNetwork and look at the tube static RBD object; at the bottom of the Collisions tab you can check on “Show Collision Guide Geometry” to see what the geometry in the RBD sim actually look like. If it looks like nothing like a cup, increase the “Divisions” in X, Y, and Z for higher precision, and check off Laser Scan.
- firebblade
- 13 posts
it seems that the best way to do this is boolean the surface with a cube
like you did.
Its a shame that collisions are so so cumbersome you actually have to spend more time thinking how to break up your object or tweaking it in order to make more accurate SDF's than making the actual particle animation.
like you did.
