Fluid Fire Examples
   13610   7   1
The front page (www.sidefx.com) and the gallery now have two fire examples that show off the new fire solver in Houdini 9.5. These were created by interns in our Toronto office and were built using the new shelf tools and the new Ramp Parameter to control the changes in color.
The Campfire example is available as a .hip file in the Exchange (Community > Houdini Exchange). This file includes both the 3D scene and the compositing network. The second fire ball example will be posted to the Exchange next week.
Enjoy…
Robert
Very nice!
Thanks very much. Every example with Houdini fluids is really needed.
Well done on some very encouraging renders! And thank you for the very complete hipfiles with some very detailed comments on each node.
i don't know what is going on with my houdini, the fire render time scare me, just 5% be completed in half hour.
One thing that probably should be noted is that the camera is set to 1600x900 you could probably have it set to something like 720x405 to get much quicker renders.
The only pass that should be very time consuming though is the flicker_pass which does a lot of raytracing with instanced lights… I wouldn't expect either simulating, or rendering of the flames to be as bad as you describe.
Stephen Tucker
VFXTD
thanks,Allegro
it is instance light that consume a lot of time.
everything is ok except instance light.
rmagee
Just as a quick update; the second example, the fire ball igniting the surrounding fuel, has now been added to the Exchange.
Enjoy!
These are excellent!
www.alan-warren.com
