If I may suggest ONE thing in Houdini,
Why the app can't remember that I prefer with Autosave on?
I always have to remember to turn it on, each time I start the app…
That's pretty dangerous.
Autosave toggles...
13731 13 6- lukasdesign
- 42 posts
- Ondrej
- 1081 posts
You can script this yourself using the autosave hscript command.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=4774 [sidefx.com]
- lukasdesign
- 42 posts
- pbowmar
- 7046 posts
I use the following in my 456.cmd file. It asks me each time Houdini starts if I want to turn on Autosave. It doesn't do it in Hscript/Hbatch (Hython, not sure) which is convenient since you only want it on in Houdini or Escape.
The 456.cmd goes in $HOME/houdini9.5/scripts by the way. If you're on Windows and don't know what your $HOME is, open a Textport in Houdini and type “echo $HOME”
If you really really want it on all the time (not a good idea IMO) then you can just do this in your 456.cmd
autosave on
Peter B
# Ask about turning on Autosave
# but only if running interactive Houdini session!
set fullver = `run(“version -n”)`
set app = `arg($fullver,0)`
if(`strcmp($app,“hscript”)` < 0 && `strcmp($app,“rscript”)` < 0 && `strcmp($app,“hbatch”)` < 0)
set turnOn = `run(“message -b Yes,No -d 0 Turn on Autosave?”)`
if($turnOn == 0)
autosave on
endif
endif
autosave on
Peter B
if($turnOn == 0)
autosave on
endif
endif
Peter Bowmar
____________
Peter Bowmar
____________
- JColdrick
- 4140 posts
I can't stress enough the importance of learning to save yourself(as Peter infers), not letting the software do it. The reasons?
1. You save at critical points(which might be constantly during a critical juncture!) instead of random points which require you to hunt through files and *hope* you caught all the things you really needed. Saving at critical points means stepping back is instant, not a flow-distracting and error-prone search.
2. Many software apps don't autosave! Don't let it be a crutch!
3. When you get into serious production, autosaving will be like getting a kick in the face at regular intervals. Hip files get big. It's fine in a program like Nuke which has scripts of only a few K for even the most massive scenes, but not 3D.
Oh baby have I lost some doozies back in the day because I forgot to save. However, it's been many, many years since it's happened, and that's because those screwups have trained me. I never lose more than a few minutes or so's worth of work because of external forces(or internal brain farts). It needs to be automatic, just like driving a standard car. Don't rely on a software feature to backup. Programs are stupid. People are smart.
J.C.
J.C.
John Coldrick
- Mikael_Amion
- 129 posts
JColdrick
Something that would be cool though is incremental autosave that audits and logs the difference between files. I’ve never seen it in any software but how neat it would be. I save often and when I want to go back through my .000x files it is sometimes difficult to remember what changes there were even if the saves are critical.
- JColdrick
- 4140 posts
- pbowmar
- 7046 posts
I agree with John on the “make sure you save yourself” side of things, but I use Autosave also, constantly, as a backup to that Autosave has saved my ass quite a few times, as I either was so “in the groove” I hadn't saved, or something happened (power, crash etc) that caused me to lose work.
The nice thing about Autosave is that the files get saved to a different filename. This means you get a stream of Autosaved files (I limit mine to 20, which at an autosave interval of 1 min I get 20 minutes worth of backups) as well as when you hit Ctrl-S you also get your own “snapshot” of where you were working, like John describes.
I've never found the speed to be an issue, at least for myself, even in a big 50 meg Hip file (no, I never have locked SOPs) it saves pretty quick.
Peter B
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
- EigenAlex
- 639 posts
- lukasdesign
- 42 posts
- lisux
- 581 posts
Programs are stupid. People are smartFor the same reason machines never forget simply do things, and humans sometimes forget.
I also save at important moments and save my checkpoints, but man, everybody always forget to save and then is where autosave have save me so much time …..
Un saludo
Best Regards
Pablo Giménez
Best Regards
Pablo Giménez
- Grendizer
- 375 posts
- pezetko
- 392 posts
https://www.sidefx.com/forum/topic/45068/ [www.sidefx.com]
https://www.sidefx.com/forum/topic/25350/ [www.sidefx.com]
https://forums.odforce.net/topic/22589-default-autosave/ [forums.odforce.net]
Edited by pezetko - July 26, 2018 07:16:44
- kevinthebright
- 214 posts
