maya viewport 64bit 2008 8.5 and nvidia
   5872   6   4
encountered a strange problem in perspective viewport of Maya 8.5 maya 2008 64bit version. When I create an object in the full perspective viewport, rotating the object several times (alt + LMB) and the screen will cease to be redrawn/refreshed(I cannot rotate the object anymore).
If I switch back to four viewport mode, then the perspective screen will be redrawn and reflects my last action on the object, but the problem will come back again if I rotate the obj inside the persp viewport.
This problem seems to happen only in XP 64bit environment, I cannot reproduce it in 32-nit XP. Does anyone has idea what possiblly cause this issue. Thank you.
may pc is
quad core q6600 8500Gt 4gbram
sorry no houdini talk
jabranbaig
senior cg Artist
Turn off Threaded Otimization in NVidia controlPanel->Manage 3D settings
for your future reference…
http://area.autodesk.com/index.php [area.autodesk.com] :roll:
where am I?
thanks for that there is fix by switching to 7600GT and not using 8500GT
Locked_Up
Wow we're answering Maya questions too now… 8)
Hadn't you heard? Houdini is the new Maya!
Peter Bowmar
____________
hurry .. get rid of the shelf tools or the forum is doomed!!
