Its strange that I can't find any discussion about problem with the type properties editor because I encounter a lot of problem with it when creating custom operator (VEX BUILDER) that make it literally unusable.
- Error message not updating
Say I have an error with my code, I edited the code and applied the changes, the node doesn't update and I need to disconnect the node and reconnect again in order to see if the new code is valid or not.
- Inconsistency between the code and the node
Sometimes all the input/output plug of the node just disappear in the network view even though all parameter in the properties editor are still intact, and there is no way I could make it reappear again.
- input/output resetting randomly
After editing and applying the code, houdini just freak out and it remove all the input/output parameter and again there is no way I could recover them, this drive me crazy when I have spent quite some time setting up the interface.
Is it just me having these problems?
I am using 9.5.241 64bits
Type properties editor too buggy?
2893 0 0- Takeshi
- 25 posts
