Q about NURBS
   5366   3   1
Hi!
I created a NURBS model, and to my surprise mantra won´t render it: it will render only the skinned part of it. What do i need to do in order to render the entire model?
And a another thing: if i create a simple NURBS circle and try to render it, mantra crashes. Is this a bug or is it only on my PC. Im using Houdini 9.5.360 in WinXP 32
-Kimmo
nurbs_test.hipnc (38.1 KB)
As your file produces the following, I would check try reinstalling H. or try a different build.
Nurbs circle renders without issue on my system.
I changed to Houdini 9.5.368 - no change: render is still the same and mantra crashes when trying to render a nurbs circle
KiLa
Hi!
-Kimmo
It looks like jatero rendered on OS X. I tried on Linux & Windows, and the file seems to render just fine (even when turning on “Keep Primitives” on the skin SOP).
Sorry I couldn't reproduce the issue.
You might try a convert SOP and convert NURBs/Bezier Curves into Trimmed NURBS patches (or polygons) to see if that works around the problem on your machine.
