Construction History
   Views 4693   Replies 5   Subscribers 2
Hello All,
I'm building a model in Houdini, and the node network is getting a little extensive. Is there any way to blow away the “construction history” as you would in other packages? Essentially merge all the nodes into one new node? I figure I could export the geometry (as an .obj), then re-import it but I'm wondering if there is a more direct rout?
If life was fair, the horse would get to ride half the time.
Wherever you wish to cut it off you can lock that sop and delete all it's inputs.
http://www.sidefx.com/docs/houdini9.5/model/lock_nodes [sidefx.com]
If it's just network editor congestion you are worried about you can also just collapse all your nodes into a subnet.
Perfect, That's exactly what I was looking for. I was partly concerned about network congestion, and partly concerned with file size once I start adding more detail. Thanks!!
Just a reminder that the node network is not a “construction history” like other software and doesn't accumulate in ram like they do.
MMB on any node will show you the memory that is being consumed to that point.
“everything is coincident”
For years now, I've been saying that there's no need to delete construction history in Houdini. If you're running into large SOP networks, there's two very simple techniques:
1. Lock your last SOP, save and restart Houdini.
2. Turn on more conservative SOP caching by setting the cull level >= 3.
edward
Can you explain more about how Cull level works in the SOP cache.
Also can memory be saved playing with the OBJ cache, or this just cache transformations?
Another thing I usually do when dealing with modelling is saving the state I want to “freeze” as a .bgeo file, place a File SOP and continue from this point, this way I alway keep a very small footprint in the scene size cos all the geo is outside. Sometimes this helps a bit.
Un saludo
Best Regards
Pablo Giménez
