Lost textures while network rendering
   3055   2   0
Hi ,
I can't render textures when using network rendering , I tried many tests like mapping all the drives containing textures and hip , sharing all the drives , and rendering from other PCs . The results are the same , only the master PC shows a part of textures while the others not . The image looks like a mosaique . Hserver is running and the verbose shows that all PCs are working .
Regards
2 Dells Precision with vista 64
4 PCs P4 with XP 32
Offhand sounds like a port being blocked…check your firewalls and/or router
J.C.
John Coldrick
Firewall is inactivated , but i will check the rest .
Thanks.
