So I'm trying to vary the thickness of a tube in L-Systems for a school project. I tried using the ! command but when I add it to rules my tree breaks into pieces. Any help would be appreciated.
Blinky :shock:
L-System turtle commands
4763 2 1- Blinky
- 6 posts
- Allegro
- 696 posts
I prefer to use the poly wire to make the skin of the lsystem rather than using the tube settings on the lsystem.
I wouldn't have expected that using a ! would change the probability in your rules :-/ I'm not sure if that's a bug or not.
Also, your last rule wasn't being used at all due to the way your probabilies were set-up.
Stephen Tucker
VFXTD
VFXTD
- moonlightkiss
- 156 posts
I dont see the tree breaking but I do see the bang command changing the tree, and I've always wondered if that's a bug. I figured it was part of the plant growth algorithm.
Blinky - if you use :0.5 on one rule, then you have to use it on all the rules or it wont evaluate correctly.
“In the beginning the Universe was created. This has made a lot of people very angry and has been widely regarded as a bad move.” - Douglas Adams
