Hi all, i'm tourning from version 6.0.286 to 6.0.340, all works fine but my
otl library for my renderman shaders that i used with 6.0.286 don't work properly under 6.0.340.
I can install the otl library but when i create a new SHOP using ne of my shaders in the parameters pane the parameter dialog for the shaders appears blank, i can load the SHOP but the parameters disappears.
I use to make the otl the next command line
rmands -p -g 8 -L OPlibRMan.otl *.slo
Any clue???
Problems with OTL's in H6.0.340
2924 0 1- lisux
- 581 posts
