using python in Font Node
   Views 4854   Replies 2   Subscribers 0
Hi all,
I want to write a python expression in the text field of the font parameter.
When I try to use “chr()” to write an ascii sign it whon't work. Is there something special to do?
Thanks you for your anwser.
p.s.: I'm a houdini noob
In the parameter pane of your Font SOP, first change the default expression language from Hscript to Python. Now right-click on the Text parameter and choose Channels and Keyframes > Set keyframe. Click on the Text label once to toggle it into expression mode. Now just replace the value with your chr() code.
Thank you verry much edward.
It works great.
nico
