Two Errors In the Windows H10 10.0.249.3 Builds
   21157   23   0
Checked the forum and I don't see this posted yet, but on two different machines I'm getting two errors on the 32 and 64 bit Windows builds of 10.0.249.3. This will probably be fixed by tomorrow but I am compelled to mention it so if SESI hasn't noticed then can know it's happening.
1) When starting up I get the following in the console:
*myPath*/houdini/config/IconMapping(95): Missing semi-colon
This one is easy to fix (which I did).
2) When adding a camera then render using Mantra I get the following in the console:
cam1 evalInt: Invalid parameter name trange
Anyone else getting this?
This was noted earlier and has been addressed.
I believe the builds on the download page were also patched.
I have the same problem :CPROGRA~1/SIDEEF~1/HOUDIN~1.3/houdini/config/IconMapping(95): Missing semi-colon
I downloaded the production build.
^_^
At what time did you download it? They should have been patched by the time of the official announcement.
PS. Beta users had early access to the unpatched build.
I downloaded it one hour ago.
^_^
4 hours ago, same mistake:
Doesn't effect the functionality though.
I liked the Mustang
We're looking into it right now. It looks like the patched builds might not have made it onto the web server.
Wolfwood
This was noted earlier…
Really? Looks like my searching powers failed me.
edward
I know ykcosmo answered (and he has downloaded it more recently) but I'll mention I downloaded the 32bit about an hour after announcement and the 64 bit about 3 hours after announcement.
Ok, the patched are really there now. Thanks!
Hallo guys!
I've downloaded the same build 10.0.249.3. on Windows 32 and I've
noticed that when I go to > File > New = Houdini unexpectedly STOPS!!!
Thanks in Advance
LabMarino ops:
Check on your taskbar. Is there a new dialog asking for you to discard/save your changes?
For your info, the 10.0.249.3 runs flawless in the Linux 64bit ubuntu version.
Good luck
Anders
Hi Edward
everythings is just setup like version 9.5!
I don't really know why it happens!
Kind Regards
LabMarino :cry:
I can not install houdini10 x64 in my pc ..The instalation stops about 80% done.. when execute: \bin\gfont.exe is running.. Someone can help me?
TharsoBrasil
Hi there,
Welcome to the forums! I did a quick search with “gfont” as the keyword and found two [sidefx.com] threads [sidefx.com].
Good luck!
Cheers!
steven
stevenong
TharsoBrasil
Hi there,
Good luck!
Cheers!
steven
the two methods didnt work here.. I am running windows 7 x64 ..
Execute: “C:\Program Files\Side Effects Software\Houdini 10.0.249.3\bin\gfont.exe” -Sq -o “C:\Program Files\Side Effects Software\Houdini 10.0.249.3\houdini\fonts\font.index” !!STOPS HERE!! always x32 x64
I think you may be the first to have tried on Windows 7. If gfont doesn't, don't worry about. It just means that TrueType fonts might not work. You can always try to rerun it at a later date (via the command line tools). I'd try to start up Houdini regardless and see how it works.
geneome
BTW, I don't think I'm getting this. This from a new file? I tried:
- Launch Houdini from console
- Ctrl+click on Sphere
- Ctrl+click on Point Light
- Ctrl+click on Camera
- Render > Create Render Node > Mantra
- Click on Render button in the parameters
edward
I didnt understand sorry.. then how I will finish the installation?
9.5 run easy in windows 7
TharsoBrasil
Click whatever buttons you need to close the dialogs. When you finish, do you not see Houdini 10 in your Start menu?
That's interesting because I didn't think anything changed in the TrueType font handling between 9.5 and 10.
