new to Hdk - How to get Object Matrix?
   5707   5   0
I am a programmer who until now has been developing plugins for Maya, and now I turn to houdini hdk.
My first project is to implement a houdini spine with slerp interpolation with 720 degrees of freedon (I have already implemented in maya, you can see it here SlerpSpine: http://alanstanzione.netsons.org/AlanStanzione-ShowReel09.mov [alanstanzione.netsons.org] ).
Yet I was able to interpolate two quaternions using a chop network and a chop VOP whit some other nodes. But i want to create a single nodel like the houdini InverseIk solver.
I looked at the hdk doc , but I found it very poor. But mostly I have not found a documentation of the various classes of development kits like doxygen or another system. If you look the maya api doc it's much more complete.
Now I'm studying the two examples CHOP_Stair and CHOP_Glove. Now my first question is this:
You can create an input parameter that specifies the path of an object, such as inverseIk where you pass the path of the bones. If this is possible how do I retrieve the transofrmation matrix of that object? Which class should I use?
Thx
Alan
Hi there,
You can find some unofficial resources for the HDK over here:
http://odforce.net/wiki/index.php/HoudiniDevelopmentKit [odforce.net]
…including Doxygen pages. I still need to get hold of, (or output myself) Houdini 10 Doxygen pages.
jason_iversen
Hi there,
hi jason,
thx for the link, but this is a simple documentation created automatically with doxygen without a minimal explanation of member's classes.
Sidefx really has never published a document of this kind?
Hi Alan,
It's OBJ_Node class, there is a bunch of methods defined in OBJ_Node.h
f = conserve . diffuse . advect . add
fx td @ the mill
iaiotom
Untested code
UT_String path;
// … set path from parm
OBJ_Node *obj = CAST_OBJNODE(findNode(path));
// … check if obj is NULL … eg. if path is an invalid path
UT_DMatrix4 xform;
obj->getLocalToWorldTransform(context, xform);
Thank you edward and hoknamahn
