can't run .cmd files from pftrack
   3318   2   1
Hi all. I'm trying to run a .cmd file generated from pftrack 5. Whether I use ‘run script’ from the file menu or ‘source …file location’ from an hscript window I get an error that CDocuments can't be opened. Any ideas what that means and/or is there a way to modify the script file to get around this weirdness? Thanks for any help.
I'm guessing that the space in the folder name is causing some grief.
Try copying the file to a temp folder (Ctemp/ for example) and try running it from there.
G
I put the file in C:\ and it worked. Thanks for the help.
