Disabling asset parameters
   3203   4   0
I'm wondering if this is possible.
I have made a digital asset which takes in two inputs. I would like to disable some of the parameters if nothing is plugged into its second input.
By disable I mean grey out the parameter so it cannot be used by the user - using the “Disable When” option.
What I'd do is create a toggle parameter and have an expression in it that queries if there are two inputs. If there aren't it evals to off and you can have the disable when of your parms linked to that one.
Thank you, that was really simple I don't know why I didn't think of that.
For anyone who reads this and wants to know more, I created a parameter and used an opninputs(“.”) expression in its default value. This will give the number of inputs and now the other parameter can be disabled if this parameter is below a certain value.
you can also use the “Disable When” parameter on the type properties
Training Lead
www.sidefx.com
sweet.
{ hasinput(0) == 1 }
